[GRASS-dev] Developing GIS application using Grass and Java on
Windows XP
andrea antonello
andrea.antonello at gmail.com
Tue Jan 20 11:59:25 EST 2009
Hi Leon,
> Hi, I need some help for a project with my friends. We need to design a
> desktop application that takes coordinates of a place and show the area of
> that coordinates to user. We intend to use java for whole project. In the
> application we will use some shortest path algorithms and using some user
> data we will find a path.
> Anyway, I want to ask something different:
> After user enters the coordinates we need to get the map of desired area and
> show it to user. While user is moving the mouse over the map, we need to
> show the characteristic of the point that mouse arrow is on. I mean if the
> arrow is over a river we need to inform user that he/she is pointing a water
> area or the elevation data of where user is pointing. I hope I made it a bit
> clear. I have no experience over either Grass or GeoTools or OpenGIS. In
> Grass i know that it has capabilities of using vector and raster data
> models. Visualization is also Grass's capability as i know. But which
> platform I will use is a big mystery for us now. Grass is built in C and we
> want to use Java for our project. Will that be a problem when we need to
> integrate Grass part to our whole project.
> Also if i want to develop the application with Grass, should i use Linux
> distribution? Can i develop on WinXP? What are your suggestions?
I guess you are a bit confused.
GRASS is a complete desktop GIS and library mainly written in C.
Geotools is a GIS library written in java.
With OpenGIS is probably mean the GIS standards.
Probably the best way to exploit a big part of GRASS and use Java, is
the JGrass project, which you can find at www.jgrass.org. If you only
want the library part and need no guy, an interesting approach would
be to attach yourself to the native bindings that GRASS supplies.
Would be interesting to see those results :)
Best regards,
Andrea
> Thank you...
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
