[GRASS-dev] Re: [GRASS-user] Aspect direction in r.slope.aspect
Helena Mitasova hmitaso at unity.ncsu.edu
Tue Jan 20 16:49:41 EST 2009
On Jan 20, 2009, at 3:16 PM, Markus Neteler wrote:
> Helena,
> I guess this is a question for you. If you post from
> hmitaso at unity.ncsu.edu it
> reaches grass-user directly.
> Markus
> On Tue, Jan 20, 2009 at 8:39 PM, Moskovitz, Bob
> <Bob.Moskovitz at conservation.ca.gov> wrote:
>> Hello Grass Users,
>> I was just wondering why aspect is measured from the east and
>> increased
>> counterclockwise instead of the north and clockwise?  It seems to run
>> counter to what is done in other GISs.
at the time when it was implemented there was no other major raster
GIS (no Spatial Analyst, only
some research software and each used different rule, based on the
background
of the developer), so it was done to conform how the angles are
measured in math (east is your +x
and the values increase counterclockw).
I vaguely remember discussions on whether to change it to conform with
the "aspect as azimuth" concept with 0 pointing towards North but
there were already too many
people used to the way it was originally implemented that it was
safer to keep it.
(we had to make the decision for aspect in v.surf.rst as well and we
decided
to keep the math convention to make it consistent with r.slope.aspect).
GRASS7 provides opportunity to change it and make sure that all
modules that compute and use
aspect or flow direction conform to the same rule. But it would be a
major undertaking that could
break a lot of scripts - I am not sure it is worth it and whether
anybody would actually be
willing to do it - it really depends on what your background is.
So if there are people who think this is really important and there
is some official standard that
says what it should be and there are some volunteers to actually work
on it, please post
to the grass-dev list,
Helena
>> Bob
>> Bob Moskovitz
>> Research Analyst I
>> Seismic Hazard Zonation Project
>> California Geological Survey
>> http://www.conservation.ca.gov/cgs/shzp
>> CONFIDENTIALITY NOTICE: This communication is intended only for
>> the use of
>> the individual or entity to which it is addressed. This message
>> contains
>> information from the State of California, California Geological
>> Survey,
>> which may be privileged, confidential and exempt from disclosure
>> under
>> applicable law, including the Electronic Communications Privacy
>> Act. If the
>> reader of this communication is not the intended recipient, you
>> are hereby
>> notified that any dissemination, distribution, or copying of this
>> communication is strictly prohibited.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Open Source Geospatial Foundation
> http://www.osgeo.org/
> http://www.grassbook.org/
