[GRASS-dev] Re: [GRASS GIS] #459: lib/cairodriver uses FontConfig
but doesn't link against it
trac at osgeo.org
Fri Jan 23 16:49:46 EST 2009
#459: lib/cairodriver uses FontConfig but doesn't link against it
Reporter: glynn | Owner: glynn
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Display | Version: svn-trunk
Resolution: | Keywords:
Platform: Unspecified | Cpu: All
Comment (by glynn):
Replying to [ticket:459 glynn]:
For now, I've added $(FCLIB) to EXTRA_LIBS in lib/cairodriver/Makefile.
I still need to add the configure checks etc to actually set this
variable.
AFAICT, it only matters if you use -Wl,--no-undefined; in that case you
can use e.g.
make FCLIB=-lfontconfig
until FCLIB gets defined.
Ticket URL: <http://trac.osgeo.org/grass/ticket/459#comment:1>
