display in grass7 [was: Re: [GRASS-dev] r.watershed]
Markus Neteler
neteler at osgeo.org
Fri Jan 23 17:14:01 EST 2009
On Wed, Jan 21, 2009 at 11:51 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> >> P.S. I often do grass stuff from home over the net. For grass7 display
>> >> through gui, even clicking off or changing
>> >> the names of layers is rather time consuming compared to d.rast with x0 (I
>> >> have cable).
>> >> Any hints, tricks on how to display maps fast when testing would be
>> >> appreciated.
>> > You could try ximgview. See [1] for Glynn's explanations of how it works.
>> > and it gets updated automatically).
>> Could you wrap this up into some d.mon command? Would be cool
>> unless there is a wx based monitor system.
I tried the suggestion had success after changing USR1 to SIGUSR1:
cat d.mon
#!/bin/sh
export GRASS_PNGFILE=/tmp/grass7map.bmp
export GRASS_PNG_MAPPED=TRUE
d.erase # create the file
export GRASS_PNG_READ=TRUE
ximgview map.bmp percent=0 &
export GRASS_NOTIFY='kill -SIGUSR1 `pidof ximgview`'
# d.* commands follow
(I also tried gqview which offers limited zoom capabilities.)
Markus
