[GRASS-dev] Re: [osgeo4w] #37: grass: wxpython gui issues
trac_osgeo4w at osgeo.org
Sat Jan 24 15:39:06 EST 2009
Reporter: jachym | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Package | Version:
Resolution: | Keywords: GRASS
Comment (by martinl):
Replying to [comment:5 jachym]:
> What does not work:
> * wx-nviz (no error message, when you switch the monitor to 3D view,
nothing happens)
> * wx-v.digit -- Only message I get is
> Unable to initialize the display driver, see README file for more
informations.
> Details: 'NoType' Object has no attribute 'OpenMap' (no module named
grass6_wxvdigit).
> Is the grass6_wxvdigit compiled ?
AFAIK, wxvigit and wxnviz are not compiled. With RC3 it should be possible
(at least wxvdigit).
> * when I want to display raster/vector file, only mapsets are listed,
but no maps in the d.rast/vect GUI form. In the command line is:
> g.mlist: command not found
GRASS need to be compiled with regex support.
Fixed in http://trac.osgeo.org/grass/changeset/35574 to use g.list on
Windows instead of g.mlist.
> * I did not manage to run *any* of raster modules. Nothing happens
simply. Maybe it is the g.mlist issue?
> Shall I open new tickets for every of these issues separately?
> Some screenshots
> * http://les-ejk.cz/tmp/grass_windows_tcltk.png
> * http://les-ejk.cz/tmp/grass_windows_wxpython.png
already fixed in http://trac.osgeo.org/grass/changeset/35574.
Martin
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/37#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
