[GRASS-dev] [GRASS GIS] #463: Display error in wxdigit
GRASS GIS trac at osgeo.org
Sun Jan 25 03:36:49 EST 2009
 Reporter:  Vincent                    |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                     |      Status:  new
 Priority:  minor                      |   Milestone:  6.4.0
Component:  wxGUI                      |     Version:  unspecified
 Keywords:  digitize,areas,fill color  |    Platform:  Unspecified
      Cpu:  Unspecified                |
 A little defect in the display when digitizing a vector map containing
 areas:
 areas (ie boundary+centroid) should appear with a fill color.
 If a boundary defines an island:
    * it turns filled (always in white, noticeable with a b.g. raster)
 eventhough not provided with a centroid, when the surrounding area is
 defined;
    * adding a centroid to make it an actual area, it remains white (not
 the color set for areas).
 In the case of polygons void of centroids, completely surrounded by areas
 (not really islands, but let's say "holes"), the problem does not arise.
 Vincent
Ticket URL: <http://trac.osgeo.org/grass/ticket/463>
