[GRASS-dev] latlon support
Glynn Clements
glynn at gclements.plus.com
Tue Jan 27 12:08:05 EST 2009
Markus Metz wrote:
> > Requiring code to explicitly use specialised (spherical-aware)
> > functions in place of +,-,<,>,== etc is not a realistic strategy.
> It seems the display does so when zooming out or panning. The Chukchi
> Peninsula and other features are copied around and displayed on both
> sides,
This is currently done in the display library (lib/display/draw2.c).
> I haven't done that in the vector, there all features are present
> only on one side. This is not a complaint about the display, I like it
> that way.
> I think my questioning started because the region settings including map
> extends are restricted to the 180 degree lon and 90 degree lat limits
> whereas vector operations can exceed these limits causing problems later
> on. To make grass handling of latlon coordinates consistent all around,
> either the limits on region settings must be relaxed (taking care of all
> the associated risks) or latlon vector coords must be forced into the
> latlon limits by some lower-level handling.
Alas, it isn't just the coordinates, but the topology. E.g. for
Antartica, you have to add south, east and west edges to get a closed
region in Euclidean space.
> The currently allowed mix is confusing.
Indeed.
