[GRASS-dev] latlon support
Glynn Clements
glynn at gclements.plus.com
Tue Jan 27 20:36:43 EST 2009
Markus Metz wrote:
> How about reversing the current policy? Restrict both raster and vector
> maps to the 180 degree lon and 90 degree lat limit, that avoids
> duplicate features within a map. Allow the region to be set anywhere
> between -360 and 360 lon but restrict the width of the computational
> region to 360 degrees lon to avoid duplicates.
That is problematic for computations which use a window (e.g.
r.neighbors, r.proj, r.mfilter etc) on a whole-earth map. For that,
you need 360 degrees plus the width of the window.
[The same issue applies at the poles, but people don't normally care
about the poles if they're working in lat/lon.]
> Wrap map contents to the
> current computational region if any map contents exist that fall into
> the computational region. This would allow traversing the datum border
> without gaps or breaks, e.g. for raster resampling. The display is not
> affected, apart from "zoom to the current computational region".
> I'm afraid you have thought of that possibility before and found flaws
> in it. Apart from rewriting a lot of code...
AFAICT, the most important case to solve is when the region is set to
the Bering strait, and a vector map has Alaska at ~180W and Sibera at
~180E. Some of the data will need a 360-degree shift to obtain the
correct relative position.
