[GRASS-dev] Re: [GRASS GIS] #397: v.clean creates polygons instead
of holes
trac at osgeo.org
Sat Jan 31 10:46:31 EST 2009
#397: v.clean creates polygons instead of holes
Reporter: cgsbob | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by mmetz):
The problem is the detail of the vector map and the threshold for v.clean
tool=rmarea. With a threshold of 2800 you reduce the vector from input
Number of areas: 27613, Number of isles: 17107 to output Number of areas:
1362, Number of isles: 1127. This is far too much, too many boundaries and
centroids are deleted or rewritten to the coor file, topology can not be
properly maintained on the fly: sometimes an existing centroid for an area
can not be found. Although the boundaries have been deleted, the centroid
is still there and assigned to the (new) area it lies in when topo is
fully built again (the output also has duplicate centroids, for the same
reason). What was an area without centroid is now an area with centroid,
GRASS speak meaning something similar like ESRI speak "polygon instead of
hole". What may in theory work is to rewrite Vect_remove_small_areas() so
that topo is completely and properly rebuild every time an area is
removed, but that is not an option, cleaning would take ages. v.clean
tool=rmarea seems to work fine as long as not more than roughly 25% of the
areas and isles are removed.
Since you are not interested in this high level of spatial detail present
in the vector lszone10, you can also
1. in the raster lszone replace NULL with 0
2. run a neighborhood filter window size 5 operation median
3. replace 0 with NULL in the filtered raster
4. r.to.vect, gives me 3136 areas and 3001 isles
optionally 5. v.clean tool=rmarea thresh=2800 if there is still too much
detail
Works like a charm, everything done in a few minutes.
Regards,
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/397#comment:9>
