[GRASS-dev] Re: [GRASS GIS] #465: r.proj.seg thins along null areas
and raster bounds for bilinear and cubic methods
trac at osgeo.org
Sat Jan 31 19:53:32 EST 2009
#465: r.proj.seg thins along null areas and raster bounds for bilinear and cubic
methods
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: major | Milestone:
Component: Raster | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:10 kyngchaos]:
> OK, something like this? Ignoring the wraparound for now, new set of
patches and new source for fallback interp functions.
> I made all interp functions return a status value:
> * 0 on successfull non-null interpolation OR if the nearest input cell
is null -> no further interpolation required
> * 1 if the interpolated output is null -> fallback to the next
interpolation level
There is no need to modify the existing functions; just check whether the
calculated value is null.
Also, it would have been better to attach the changes as a single patch,
i.e. "svn add" the new files then use "svn diff" to create a patch
containing all of the changes.
> I don't know about inlining, so feel free to suggest how to do that, if
you think it will speed it up significantly.
Actually, I doubt that it matters.
Ticket URL: <http://trac.osgeo.org/grass/ticket/465#comment:11>
