[GRASS-dev] Re: [GRASS GIS] #667: please allow to export projection
information in more formats
trac at osgeo.org
Thu Jul 2 03:15:58 EDT 2009
#667: please allow to export projection information in more formats
Reporter: timmie | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 6.5.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords: g.proj
Platform: Linux | Cpu: x86-32
Comment (by hamish):
> Do you not think that the format +proj=longlat +ellps=WGS84 +datum=WGS84
> cannot be converted back to the corresponding EPSG number?
adding datum transform parameters is a non-reversible process.
likely there is precision and other translation/expansion issues as well.
Neither Frank's EPSG DB -> PROJ.4 epsg file nor QGIS's +proj4
term matching code has a solution yet, and that's before you consider that
we maintain our own ellipse and datum tables which
may add and/or modify terms.
I don't want to say it can't be done, but it's not easy and I would not
trust well any result which claims to be able do it to be complete. IMHO
better to just use the explicit expanded version and not worry..
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/667#comment:7>
