[GRASS-dev] Re: [GRASS GIS] #670: add support for alternative
coordinates
trac at osgeo.org
Thu Jul 2 03:50:33 EDT 2009
#670: add support for alternative coordinates
Reporter: timmie | Owner: martinl
Type: enhancement | Status: assigned
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: map display, preferences, workspace
Platform: Linux | Cpu: x86-32
Comment (by martinl):
Replying to [comment:7 timmie]:
> > GUI preferences -> Display -> Projection statusbar setting.
> Martin, thanks.
> But it doesn't seem to work.
> I tried it on UTM projection with EPSG 4326.
> But the status bar show still metric coordinates instead of WGS84
lat/lon
The required field is proj4 string not the EPSG code. So you can
* directly write proj4 code
* or load epsg code (takes quite long time) and choose the code
Then press 'Apply' or 'Save' to get it working.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/670#comment:8>
