[GRASS-dev] Re: [GRASS-user] grass 6.4 rc5 and python scripting
Hamish hamish_b at yahoo.com
Fri Jul 3 03:59:35 EDT 2009
> > > In order for g.parser to work, the file teste.py needs to be in
> > > your PATH.
Glynn wrote:
> > This is actually a bug in G_parser() and G_gui(). menuform.py is
> > being passed the base filename rather than the complete path.
> > There isn't any other reason why the script needs to be in the
> > path.
> I've fixed this in 7.x with r38126. However, menuform.py
> still tries to run the script using its basename.
should this be backported? if so, to which branches?
Hamish
