[GRASS-dev] [GRASS GIS] #675: r.proj's "use different location" error while working in different dbases
GRASS GIS trac at osgeo.org
Sun Jul 5 07:21:22 EDT 2009
 Reporter:  nikos                                                         |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                                                        |      Status:  new
 Priority:  blocker                                                       |   Milestone:  6.4.0
Component:  Raster                                                        |     Version:  unspecified
 Keywords:  r.proj, dbase, location, indbase->answer, inlocation->answer  |    Platform:  Unspecified
      Cpu:  Unspecified                                                   |
 I have "wgs84" locations in different dbases, for example:
 "/grassdb/ellas/wgs84" and "/grassdb/global/wgs84".
 I want to "r.proj" something from "ellas" to "global" dbase and I get
 the following error:
 # working in "global"
 g.gisenv
 GISDBASE=/geo/grassdb/global
 LOCATION_NAME=wgs84
 MAPSET=PERMANENT
 # trying to "pull" data
 r.proj aster_gdem out=aster_gdem_ellas location=wgs84 mapset=PERMANENT
 dbase=/geo/grassdb/ellas
 ERROR: You have to use a different location for input than the current
 Even though r.proj is meant to re-project data from one location to
 another (= usually different projection definitions) within a dbase, it
 could be used to "pull" data from a different grass-dbase as in my
 example-attempt above.
 This is a bug, ins't it? I suppose the "dbase=" parameter is not checked
 at all in this case (?).
 Alternative solution with respect to the specific example here: allow
 g.copy to copy data from another dbase/location to the current dbase in a
 location with identical name and projection definition of course (?).
Ticket URL: <http://trac.osgeo.org/grass/ticket/675>
