[GRASS-dev] make install targets?
Sun Jul 5 10:17:45 EDT 2009
Markus Neteler wrote:
> >> >>> Realistically, this should wait for 6.4/7.x, when the build system
> >> >>> will get cleaned up to make it easier to build modules against an
> >> >>> installed version of GRASS.
> >> >> I would still appreciate a generic "make install" - is that now feasible?
> >> I have added a
> >> make install
> >> target to 6.4.0svn and 6.5svn. No idea how to do it for 7.
> Any hope to get that fixed in GRASS 7?
> I don't understand its Makefile system sufficiently.
The mechanism used in 6.5 can be copied almost verbatim to 7.0, but it
isn't particularly robust; there are a lot of special cases which
don't get accounted for.
One obvious improvement would be to replace the "install" targets in
the *.make files with more specific targets, e.g. "install_cmd",
"install_shlib", etc, and have the generic "install" target invoke
that. This would allow individual Makefiles to extend the install
target without having to clone the existing target.
Or the install targets could use double-colon rules; if multiple such
rules name the same target, making that target will execute the
commands for all of the rules (in no particular order). Normal
(single-colon) rules use the commands from the last rule. The main
downside with this approach is that individual Makefiles can only add
commands to the installation rule, not remove them.
Either way, any Makefile whose "default" rule isn't simply
"default: cmd", "default: lib", etc will need a custom "install"
target to install the additional files.
> >> It doesn't yet work for multi-targets such as r.mapcalc/r3.mapcalc but
> >> it also doesn't interfere. So at least GRASS Addons can now be
> >> installed easily with
> >> make MODULE_TOPDIR=$HOME/grass64/
> >> make MODULE_TOPDIR=$HOME/grass64/ install
> > Wouldn't it be simpler to just point ARCH_DISTDIR at the installed
> > version?
> Still no clue how to do that.
	make ARCH_DISTDIR=/usr/local/grass-7.0svn
The main issue here is that it won't use the files in dist.<arch>, but
will re-create them, e.g. modules and libraries will be re-linked,
HTML files will be re-generated, etc.
