[GRASS-dev] Re: [GRASS GIS] #670: add support for alternative coordinates
GRASS GIS trac at osgeo.org
Sun Jul 5 12:42:49 EDT 2009
  Reporter:  timmie       |       Owner:  martinl
      Type:  enhancement  |      Status:  assigned
  Priority:  normal       |   Milestone:  6.5.0
 Component:  wxGUI        |     Version:  svn-develbranch6
Resolution:               |    Keywords:  map display, preferences, workspace
  Platform:  Linux        |         Cpu:  x86-32
Comment (by martinl):
 Replying to [comment:9 timmie]:
 >     - please make a switch in the status bar to either native coodinates
 of the location or the projection defined in the Config
 Done in r38258.
 >     - does it check whether the projections comply?
 I don't understand what you are asking for.
 >     - please documents that: one needs to input the EPSG number and then
 press load code
 I would leave this for native speaker in the best case.
 >     - pelase enable to display the coordinates in decimal numbers: -f
 '%.8f'
 I guess you are speaking about latlong locations.
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/670#comment:11>
