[GRASS-dev] Re: [GRASS GIS] #670: add support for alternative
coordinates
trac at osgeo.org
Sun Jul 5 17:23:09 EDT 2009
#670: add support for alternative coordinates
Reporter: timmie | Owner: martinl
Type: enhancement | Status: assigned
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: map display, preferences, workspace
Platform: Linux | Cpu: x86-32
Comment (by timmie):
Replying to [comment:11 martinl]:
> Replying to [comment:9 timmie]:
> > - please make a switch in the status bar to either native
coodinates of the location or the projection defined in the Config
> Done in r38258.
Well, I was looking for a different design.
Which wxGUI python file controls the status bar?
I would like to send you a proposal.
> > - does it check whether the projections comply?
> I don't understand what you are asking for.
What happens if a users enters a EPSG code of a projection which does not
match with the projection of the location?
E.g. an adjactant UTM zone instead of WGS84?
> > - please documents that: one needs to input the EPSG number and
then press load code
> I would leave this for native speaker in the best case.
I would like to include this in the proposal.
What file do I need to modify?
Again: thanks. It come in very hand. Great!
Ticket URL: <http://trac.osgeo.org/grass/ticket/670#comment:14>
