[GRASS-dev] Re: [GRASS GIS] #670: add support for alternative coordinates
GRASS GIS trac at osgeo.org
Sun Jul 5 18:22:26 EDT 2009
  Reporter:  timmie       |       Owner:  martinl
      Type:  enhancement  |      Status:  assigned
  Priority:  normal       |   Milestone:  6.5.0
 Component:  wxGUI        |     Version:  svn-develbranch6
Resolution:               |    Keywords:  map display, preferences, workspace
  Platform:  Linux        |         Cpu:  x86-32
Comment (by timmie):
 you may need to adjust grid sizes:
         # projections statusbar settings
         box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " %
 _("Projection statusbar settings \n (enter EPSG code and press \"Load EPSG
 codes\" (and wait) or insert Proj.4 string directly"))
         sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
         gridSizer = wx.GridBagSizer (hgap=3, vgap=3)
         gridSizer.AddGrowableCol(1)
         row = 0
 The other changes will need more time.
 I need to setup pydev (my preferred IDE) to reflect the wxGUI.
 I will not apply to avn access before being sure that I can contribute in
 a reliable way.
 I do not use GRASS on daily basis. From time to time I need to work some
 tasks and days for one project.
 For the time being, count on me for improvement suggestions, only.
 What do you think about the decimal degree thing?
Ticket URL: <http://trac.osgeo.org/grass/ticket/670#comment:18>
