[GRASS-dev] Re: [GRASS GIS] #676: r.watershed: different output map options do not allow for fully qualified map names
GRASS GIS trac at osgeo.org
Mon Jul 6 03:40:14 EDT 2009
map names
  Reporter:  mlennert  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  normal    |   Milestone:  6.4.0
 Component:  Raster    |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  r.watershed
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by mlennert):
 Replying to [comment:1 hamish]:
 > you may only write to the current mapset. therefore @othermapset is not
 needed for output maps.
 > if it is given, and the value is the current mapset, then perhaps it
 should be quietly ignored. hopefully it could be done at the library
 level. if it can't be handled at the lib level I'd be inclined to ignore
 it rather than add clutter to all raster modules.
 Ok, but then the wxGUI should not automatically add @mapset when you chose
 an existing file for output. So, maybe this should be reclassified as a
 wxGUI bug.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/676#comment:2>
