[GRASS-dev] python scripts in grass6
Martin Landa landa.martin at gmail.com
Mon Jul 6 04:18:19 EDT 2009
2009/7/6 Glynn Clements <glynn at gclements.plus.com>:
>> currently in GRASS 6 PGM variable must be set including python file
>> extension, in GRASS 7 not, e.g.
>> PGM=v.krige.py in GRASS6
>> PGM=v.krige in GRASS7
>> Would be possible to change building system in GRASS 6 to unify it with GRASS 7.
> GRASS 7 now *only* allows Python scripts, so I don't think you want to
> unify it quite that far.
Probably I was unclear, I would like just to avoid having two separate
Makefiles for one Python script, one for GRASS7 with `PGM=module` and
the second for GRASS6 with `PGM=module.py`. Nothing more.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
