[GRASS-dev] Re: [GRASS GIS] #520: r.terraflow/iostream does not respect STREAM_DIR option
GRASS GIS trac at osgeo.org
Tue Jul 7 04:56:27 EDT 2009
  Reporter:  mmetz   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  major   |   Milestone:  6.4.0
 Component:  Raster  |     Version:  svn-develbranch6
Resolution:          |    Keywords:  r.terraflow, tmp
  Platform:  All     |         Cpu:  All
Comment (by mmetz):
 Replying to [comment:17 hamish]:
 > maybe part of this bug was fixed by r37295 (mid May). From July 2008
 G_parser() in 6.4 and 6.5 was silently doing nasty things to option
 settings in memory for options with upper case letters in them.
 Not respecting a user-specified STREAM_DIR option was apparently a bug of
 G_parser(), not r.terraflow. The default answer of /var/tmp or another
 system TEMP folder is IMHO not a good idea because of lack of space. Why
 not leaving it blank, if no answer is given, use the GRASS temp directory?
 That directory should always exist and I guess there is most of the time
 enough space.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/520#comment:18>
