[GRASS-dev] Re: [GRASS GIS] #671: wxgui: v.distance to_column option inaccessible
GRASS GIS trac at osgeo.org
Tue Jul 7 09:37:50 EDT 2009
  Reporter:  mlennert  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  v.distance to_column
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by hamish):
 Replying to [comment:4 mlennert]:
 > AFAIU, it's the same logic as the supported_formats() function
 > in r.out.gdal, also run before the call to G_parser().
 and the same criticism applies.
 actually r.out.gdal is much worse -- Martin can do magic in the module-
 launch GUI plucking off the map name and doing outside processing that map
 separate to the running of the actual module. So maybe his suggestion is
 not so bad after all.
 still not sure, seems like a potential method to introduce circular
 dependency problems.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/671#comment:5>
