[GRASS-dev] Re: [GRASS GIS] #671: wxgui: v.distance to_column option inaccessible
GRASS GIS trac at osgeo.org
Tue Jul 7 10:14:01 EDT 2009
  Reporter:  mlennert  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  v.distance to_column
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by martinl):
 Replying to [comment:4 mlennert]:
 > Replying to [comment:3 hamish]:
 > > I don't doubt the usefulness, but it seems slightly incongruous that
 the input parameters should be allowed to parse for available columns
 before G_parser() has had a change to run..
 > AFAIU, it's the same logic as the supported_formats() function in
 r.out.gdal, also run before the call to G_parser().
 I don't think so, it's not the same issue. In this case e.g. for XML
 output the parser returns:
 <parameter name="to_layer">
     <guidep>to_column</guidep>
 </parameter>
 The this information can be parsed by {{{menuform.py}}}.
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/671#comment:7>
