[GRASS-dev] python scripts in grass6
Martin Landa landa.martin at gmail.com
Tue Jul 7 10:21:34 EDT 2009
2009/7/7 Glynn Clements <glynn at gclements.plus.com>:
>> >> Probably I was unclear, I would like just to avoid having two separate
>> >> Makefiles for one Python script, one for GRASS7 with `PGM=module` and
>> >> the second for GRASS6 with `PGM=module.py`. Nothing more.
>> > Regardless, make needs to know which file it's supposed to be
>> > creating. If you want to autodect this, it requires new code; current
>> > or previous practice in GRASS 7 won't help.
>> Probably it would make sense to add support to the building system for
>> shell scripts again - some users have a lot of such scripts.
> Users scripts aren't relevant to the GRASS build system.
Probably users are important for us ;-)
>> Then PGM should always contain file extension.
> No, because the file extension is removed on Unix, and it doesn't
> appear in the name of the manpage or HTML file. PGM is the *name* of
> the module or script, not necessarily its filename.
That is what I was asking for. So how to avoid python file extension
in Makefiles for GRASS 6. Currently, e.g.
PGM=v.krige
fails, must be
PGM=v.krige.py
Thanks, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
