[GRASS-dev] Re: [GRASS GIS] #670: add support for alternative
	coordinates
    trac at osgeo.org
    Wed Jul  8 02:27:57 EDT 2009
#670: add support for alternative coordinates
  Reporter:  timmie       |       Owner:  martinl
      Type:  enhancement  |      Status:  assigned
  Priority:  normal       |   Milestone:  6.5.0
 Component:  wxGUI        |     Version:  svn-develbranch6
Resolution:               |    Keywords:  map display, preferences, workspace
  Platform:  Linux        |         Cpu:  x86-32
Comment (by hamish):
 Replying to [comment:23 martinl]:
 > Can we close the ticket or are there any remaining issues?
 - does Michael's note about wx.StaticBox need attention?
 - Need to consider Tim's mockup of the statusbar with proj display
 - For my 2c re. the new Projection tab in wxGUI Preferences:
  1) needs reorganizing of buttons/entries into workflow order (eg step 1
 is load EPSG, so have that first, then...);
  2) I agree that the wording could do with some improvement/ clarification
 - verbose tooltips would help (everyone can help with that);
  3) "<>" still needs removing from the end of the auto +epsg string
  4) its presence seems to me to be a bit of a trap for new users who are
 refugees from other GIS which might think this is a ''much'' more
 fundamental Preference setting than it really is. To avoid 747-cockpit
 style option overload (e.g. tcltk GIS.m layer manager add_vector_layer
 controls) could this preference, including some entries in the drop down
 toolbar menu in the Map Display window, be hidden behind some sort of "[]
 Advanced" preferences setup?
 Also, FWIW, I don't really think precision is an issue needing a user-
 settable option. As long as we provide good defaults:
 - %.3f for planimetric (units= feet or m)
 - %.8f for decimal degrees
 - %.4f for decimal minutes
 - %.3f for decimal seconds
 i.e. reporting to approximately the millimeter level will cover 99% of
 user needs & beyond current RTK GPS surveying limits relevant to GIS.
 Others can tweak the setting manually (of course keep it easy to do that
 within the code). Non-GUI & library stuff of course would continue to
 operate at full precision, I'm just talking about the mouse-over & value
 shown to the user on the Map Display status bar.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/670#comment:24>
