[GRASS-dev] Re: [GRASS GIS] #670: add support for alternative
coordinates
trac at osgeo.org
Wed Jul 8 16:26:51 EDT 2009
#670: add support for alternative coordinates
Reporter: timmie | Owner: martinl
Type: enhancement | Status: assigned
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: map display, preferences, workspace
Platform: Linux | Cpu: x86-32
Comment (by martinl):
Replying to [comment:24 hamish]:
> - does Michael's note about wx.StaticBox need attention?
From ML:
The new wx.StaticBox for projections works fine on the Mac in the version
I downloaded and compiled on Monday.
Michael
> 1) needs reorganizing of buttons/entries into workflow order (eg step 1
is load EPSG, so have that first, then...);
Loading EPSG codes is not required, your can enter proj4 string directly.
> 2) I agree that the wording could do with some improvement/
clarification - verbose tooltips would help (everyone can help with that);
Also should be documented in the manual page.
> 3) "<>" still needs removing from the end of the auto +epsg string
It's done when you choose EPSG code.
Martin
Ticket URL: <https://trac.osgeo.org/grass/ticket/670#comment:27>
