[GRASS-dev] [GRASS GIS] #681: wxpython gui-module 'g.remove' remembers all files after deleting
GRASS GIS trac at osgeo.org
Fri Jul 10 07:37:01 EDT 2009
 Reporter:  marmai              |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect              |      Status:  new
 Priority:  normal              |   Milestone:  6.4.0
Component:  wxGUI               |     Version:  6.4.0 RCs
 Keywords:  g.remove file list  |    Platform:  Unspecified
      Cpu:  Unspecified         |
 I wanted to delete a couple of vector maps with the g.remove GUI module
 (wxpython GUI). Within the GUI window I selected some vector maps and
 used the 'Run' button. Afterwards I wanted to remove some more maps
 (without closing the window of the g.remove module!). Then there are the
 maps I already deleted still in the list of the maps to remove (this leads
 to a couple of error messages when clicking the 'Run' button). If
 I click in the 'list of the maps to remove' and delete them (by using
 the 'del' key) then as soon as you select another map via the drop down
 list
 they will again be back in the list of the maps to be removed.
 By closing the g.remove module GUI and opening it again everything works
 as expected.
 I am using GRASS 6.4.0RC4 on OpenSuse10.3.
Ticket URL: <http://trac.osgeo.org/grass/ticket/681>
