[GRASS-dev] Re: [GRASS GIS] #632: Thematic Maps
trac at osgeo.org
Sat Jul 11 03:42:18 EDT 2009
#632: Thematic Maps
Reporter: voncasec | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: d.vect.thematic
Platform: Linux | Cpu: Unspecified
Comment (by martinl):
Replying to [comment:4 yytsui]:
> I spent sometime to look into this issue and consider using FloatCanvas
> http://trac.paulmcnett.com/floatcanvas/wiki to fixed this bug. However,
If we use FloatCanvas to display maps, that means probably a lot of codes
in gui/wxpython/gui_modules/mapdisp.py, mapdisp_windows.py ,wxgui_utils
and render.py has to be change. Anyone know how much effort this might
cause? And I just sent an email to
probably quite a lot of work. If you start I would suggest to make a fork
of wxGUI in grass-addons and later to merge it into trunk.
Ticket URL: <http://trac.osgeo.org/grass/ticket/632#comment:5>
