[GRASS-dev] Re: [GRASS GIS] #490: problem with gui wx with module v.db.join
GRASS GIS trac at osgeo.org
Sat Jul 11 04:43:48 EDT 2009
  Reporter:  dadedodo  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  v.db.join
  Platform:  Linux     |         Cpu:  x86-32
Changes (by martinl):
 * cc: grass-dev at lists.osgeo.org (added)
  * keywords:  => v.db.join
  * status:  new => assigned
  * owner:  grass-dev at lists.osgeo.org => martinl
Comment:
 Fixed in trunk (grass70) r38363. See also #671. Column comboboxes are
 currently writable in devbr6 (grass65) and relbr64 (grass64), so at least
 you can write column name by hand. This cannot be fixed without
 backporting changes from trunk. It will be not done for relbr64 (quite
 significant change in API) and probably also for devbr6.
Ticket URL: <http://trac.osgeo.org/grass/ticket/490#comment:1>
