[GRASS-dev] Re: [GRASS GIS] #35: Verify and uncomment Swiss datum parameters
GRASS GIS trac at osgeo.org
Sun Jul 12 06:20:54 EDT 2009
  Reporter:  neteler      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  closed
  Priority:  major        |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:  fixed        |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by pkelly):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Now fixed in r38374, r38375 and r38376. The differences in parameters are
 actually very minor from those already in GRASS so I don't know if it will
 result in any shift in reprojections (that isn't already within the margin
 of error).
 It's just a pity we can't use the gridshift file due to the current
 structure of PROJ.4 - gridshift files can only be used if they transform
 to WGS84 directly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/35#comment:10>
