[GRASS-dev] Re: [GRASS GIS] #35: Verify and uncomment Swiss datum
parameters
trac at osgeo.org
Mon Jul 13 05:27:06 EDT 2009
#35: Verify and uncomment Swiss datum parameters
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: Projections/Datums | Version: unspecified
Resolution: fixed | Keywords: CH1903, Swiss
Platform: Unspecified | Cpu: Unspecified
Comment (by pkelly):
ok, I was a bit confused when updating the upcoming release notes if to
call it an update to CH1903 or CH1903+. From comment:2 I took the new
3-param terms in r38376 to belong to CH1903+.
Yes I was confused too, which is why I asked on the PROJ.4 list for more
clarification. My understanding now is that the 3-parameter transformation
is an (almost) exact transformation from CH1903+ to ETRS89 and has the
same accuracy over all of Switzerland. Since CH1903 and CH1903+ are very
close and only ever differ from each other by a couple of metres (the
difference varies across Switzerland), it is reasonable to consider CH1903
as an approximation of CH1903+ and hence the parameters are also valid for
CH1903 to ETRS89 (with an accuracy of a couple of metres). Indeed as the
difference between ETRS89 and WGS84 (a few tens of centimetres) is much
smaller than the accuracy of the parameters as applied to CH1903, they can
be equally considered an accurate transformation from CH1903 to WGS84.
so will the 3-param terms drift at the same rate as the plate?
As mentioned above for CH1903, for the foreseeable future the difference
between WGS84 and ETRS89 due to drifting of the plate is much smaller than
the error in the 3-parameter transformation. So for CH1903 the accuracy of
the 3-parameter transformation (when used to transform to WGS84) can be
considered constant over time. (Obviously applied to ETRS89 the accuracy
is actually constant over time.)
When the 3-parameter transform is applied to the CH1903+ to WGS84
transformation you are right that the accuracy will gradually degrade over
time (a few centimetres per year). Again, applied to the CH1903+ to ETRS89
transformation it is constant.
Now I'm just waiting for someone to tell me I've missed an important
detail and got this all wrong! ;) I think we need a new library in the
free software world that separates the datum from the projection handles
all this stuff properly for best accuracy.
GRASS has never had an entry in the datum.table for CH1903+, only CH1903.
All I did in the SVN commit was to correct the 3-parameter transform for
CH1903 (and it was a very small change). I guess we could add CH1903+ in
with the same parameter set, but I wasn't sure if + signs would be allowed
in the datum name and that could take a while to check so didn't want to
rush into making that change. Ideally we would support CH1903 and CH1903+
separately, using the gridshift file for CH1903, but the way PROJ.4
currently works we can't support that...
Ticket URL: <https://trac.osgeo.org/grass/ticket/35#comment:14>
