[GRASS-dev] vector libs: file based spatial index
Martin Landa
landa.martin at gmail.com
Mon Jul 13 10:07:48 EDT 2009
2009/7/13 Markus Metz <markus.metz.giswork at googlemail.com>:
> To work with an existing vector in grass7, topology needs to be rebuilt
> because a support file is missing, the spatial index. After that
> everything is fine and grass6 can read the vector again as it is.
great!
Just trying to build vector map 'bridges' from nc_spm. The module ends
up with the 'position mismatch' error.
$ v.build bridges
Building topology for vector map <bridges>...
Number of nodes: 10938
Number of primitives: 10938
Number of points: 10938
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
ERROR: position mismatch
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
