[GRASS-dev] [GRASS GIS] #682: Allow compilation in directory with spaces
GRASS GIS trac at osgeo.org
Mon Jul 13 10:16:26 EDT 2009
 Reporter:  marisn       |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  minor        |   Milestone:  6.5.0
Component:  Compiling    |     Version:  svn-develbranch6
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
 As of GRASS 6.5 it's not possible to configure and make GRASS if it's
 source is located in directory containing spaces in it's path.
 Steps to reproduce:
 make distclean
 mv /path/to/my/grass/source "/path/with/spaces/to/grass source"
 ./configure && make
 Configure part is easy but other Make system parts are more tricky.
 --- configure   (revision 38380)
 +++ configure   (working copy)
 @@ -716,18 +716,18 @@
  ac_aux_dir=
  for ac_dir in $srcdir $srcdir/.. $srcdir/../..; do
 -  if test -f $ac_dir/install-sh; then
 -    ac_aux_dir=$ac_dir
 +  if test -f "$ac_dir/install-sh"; then
 +    ac_aux_dir="$ac_dir"
      ac_install_sh="$ac_aux_dir/install-sh -c"
      break
 -  elif test -f $ac_dir/install.sh; then
 +  elif test -f "$ac_dir/install.sh"; then
      ac_install_sh="$ac_aux_dir/install.sh -c"
      break
    fi
  done
  if test -z "$ac_aux_dir"; then
 -  { echo "configure: error: can not find install-sh or install.sh in
 $srcdir $srcdir/.. $srcdir/../.." 1>&2; exit 1; }
 +  { echo "configure: error: can not find install-sh or install.sh in
 \"$srcdir\" \"$srcdir/..\" \"$srcdir/../..\"" 1>&2; exit 1; }
  fi
  ac_config_guess=$ac_aux_dir/config.guess
  ac_config_sub=$ac_aux_dir/config.sub
 @@ -1235,19 +1235,19 @@
  # Use absolute path for aux directory so that install-sh works
  ac_aux_dir=
 -for ac_dir in $SRCDIR $srcdir/$SRCDIR; do
 +for ac_dir in "$SRCDIR" "$srcdir/$SRCDIR"; do
      ac_aux_dir=$ac_dir
      break
      ac_aux_dir=$ac_dir
      break
    fi
  done
 $SRCDIR $srcdir/$SRCDIR" 1>&2; exit 1; }
 \"$SRCDIR\" \"$srcdir/$SRCDIR\"" 1>&2; exit 1; }
  fi
Ticket URL: <http://trac.osgeo.org/grass/ticket/682>
