[GRASS-dev] [GRASS GIS] #683: Make d.scalebar look the same on
different display sizes
trac at osgeo.org
Mon Jul 13 11:37:46 EDT 2009
#683: Make d.scalebar look the same on different display sizes
Reporter: perk | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 6.5.0
Component: Display | Version: svn-develbranch6
Keywords: scalebar | Platform: All
Cpu: All |
The current d.barscale is display dependent. The scale produced looks
great on a display that's 640x480 pixels, but is unreadable on a
with barscale-big-after.png. This is also pretty easy to see by
drawing a scalebar on an X11 display then making it full screen.
I think that the scale bar size should relative to the display size,
not pixel size. I started out to fix this problem and thought it
would be a relatively minor change. However, I ended up recoded a
good deal of it because all of the relative sizes were hard coded and
duplicated in several places.
I think I've succeeded in my main goal: the proportions of the
scalebar remain the same regardless of display size. The default
behavior is very much the same as before, but a little cleaner (IMO).
The layout is changed slightly but is very similar to the original.
The only significant layout change was the positioning of the north
arrow when text is above the scale bar. It is now larger and
vertically centered in the surrounding box.
I went on to add an "enlarge" option to shrink or enlarge the scalebar
to get the text and north arrow just the right size by specifying an
size percentage (100% = default).
Hopefully, the code is a little cleaner now, but it's still not as
clean as I would like. It at least has fulfilled my immediate need.
Ticket URL: <http://trac.osgeo.org/grass/ticket/683>
