[GRASS-dev] r.recode: behaviour at limits
Markus Neteler
neteler at osgeo.org
Tue Jul 14 09:40:24 EDT 2009
On Mon, Jul 13, 2009 at 5:25 PM, Glynn Clements<glynn at gclements.plus.com> wrote:
> BTW, libraster needs reformatting; the change of prefix from G_* to
> Rast* means that parameter lists which are split over multiple lines
> no longer align, e.g.:
> void Rast_fpreclass_add_rule(struct FPReclass *r,
> DCELL dLow, DCELL dHigh,
> DCELL rLow, DCELL rHigh)
I have tried but the script in tools/ is introducing
ugly vertical white space in the variable definitions, e.g.
@@ -28,8 +30,11 @@
static int organize_fp_lookup(struct Colors *colors, int mod)
int i;
DCELL val;
struct _Color_Info_ *cp;
struct _Color_Rule_ *rule;
Some "indent" magic apparently.
Markus
