[GRASS-dev] Re: [GRASS GIS] #684: g.extension: default url should not point to grass7
GRASS GIS trac at osgeo.org
Tue Jul 14 09:48:10 EDT 2009
  Reporter:  mlennert     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  default      |     Version:  svn-trunk
Resolution:  invalid      |    Keywords:  g.extension
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by martinl):
 Replying to [comment:5 hamish]:
 > I wonder for cases where it is known that the (e.g. C vector) module
 needs no porting changes if it is possible to symlink the module dir into
 the grass7 addons svn?
 At least you need to replace
 #include <grass/Vect.h>
 by
 #include <grass/vector.h>
 > The idea is to avoid the double effort of keeping the two "branches" in
 sync.
 Patch again trunk could avoid it.
 Martin
Ticket URL: <https://trac.osgeo.org/grass/ticket/684#comment:6>
