[GRASS-dev] Re: [GRASS GIS] #620: Platform.make odd variables settings
GRASS GIS trac at osgeo.org
Tue Jul 14 13:37:05 EDT 2009
  Reporter:  frankie       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  6.4.0 RCs
Resolution:                |    Keywords:
  Platform:  Unspecified   |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:10 mlennert]:
 > I'm not talking about checking out the AddOn, I'm talking about
 compiling it. You suggest:
 make MODULE_TOPDIR=/path/to/grass_source_tree/
 > which indicates that I need the source tree for compilation...
 > I am looking for a way to get the equivalent of
 make MODULE_TOPDIR=/usr/lib/grass
 This should work in 7.0, although you also may also need to set GISBASE,
 ARCH_DISTDIR and/or RUN_GISBASE.
Ticket URL: <https://trac.osgeo.org/grass/ticket/620#comment:12>
