[GRASS-dev] Re: [GRASS GIS] #684: g.extension: default url should not point to grass7
GRASS GIS trac at osgeo.org
Wed Jul 15 02:59:08 EDT 2009
  Reporter:  mlennert     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  default      |     Version:  svn-trunk
Resolution:  invalid      |    Keywords:  g.extension
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by hamish):
 Replying to [comment:1 martinl]:
 > Another options would to provide patch for GRASS7. E.g. g.extension
 > could check if dictionary contains {{{grass7.diff}}} and patch the
 > source code before compilation.
 FWIW I have and do use a similar approach in a few other projects. (mostly
 debian packaging patches to allow things to also work on ubuntu, 64bit
 versions, etc)
 All in all I have not enjoyed the experience, I have found it quite
 painful to maintain/rebuild the patch sets every time a change is applied
 in trunk.
 but YMMV and I may well be going about it the hard way.
 2c,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/684#comment:8>
