[GRASS-dev] GRASS7 rasterlib broken?
Markus Metz markus.metz.giswork at googlemail.com
Wed Jul 15 08:54:07 EDT 2009
Martin Landa wrote:
> Hi,
> 2009/7/15 Markus Metz <markus.metz.giswork at googlemail.com>:
>> g.region rast=mymap
>> r.mapcalc "mymap.copy = mymap"
>> Displaying both maps or r.univar gives vastly different results.
>> This corrupted output is not restricted to r.mapcalc but seems to be
>> true for all raster modules.
>> grass7 updated today, no changes in my local copy, two different
>> independent systems.
>> I know rasterlib in grass7 is work in progress, but I just wanted to
>> mention it, also ask if someone else observed this problem.
> very wild guess - probably because Rast__init() is not called anywhere?
I guess you probably know best about Rast__init() and when and where it
is supposed to be called ;-) I've never heard of that function before...
Markus M
