[GRASS-dev] v.lidar category numbers
Markus Neteler
neteler at osgeo.org
Sun Jul 19 15:22:31 EDT 2009
On Fri, Jun 19, 2009 at 1:27 PM, Hamish<hamish_b at yahoo.com> wrote:
> Hi,
> I'm a bit confused with v.lidar EDGE/TERRAIN/UNKNOWN #defines.
> v.lidar.edgedetection categorizes data points as either of those three.
> output vector map includes cats 0,1,2 by layer 1.
> (also there is a DB on layer 3, but that is not important to this email)
> man page says:
> EDGE (cat = 1, layer = 1)
> TERRAIN (cat = 2, layer = 1)
> (so cat=0 is UNKNOWN ??)
> vector/lidar/v.lidar.edgedetection/edgedetection.c has:
> /* 0 = PRE_TERRAIN */
> /* 1 = PRE_EDGE */
> /* 2 = UNKNOWN */
> vector/lidar/lidarlib/PolimiFunct.h has:
> /* PRE-CLASSIFICATION */
> #define PRE_TERRAIN 1
> #define PRE_EDGE 2
> #define PRE_UNKNOWN 3
> In v.lidar.growing I don't see any of these clearly but I guess they
> must be there.
> ... I am a little confused. I'd like to update the v.lidar.edgedetection
> man page to say what cat 0 in its output means.
Via Maria Brovelli/Sara Lucca I obtained this answer
----- start cite -----
The output of v.lidar.edgetection is:
TERRAIN (cat = 1, layer = 1)
EDGE (cat = 2, layer = 1)
UNKNOWN (cat = 3, layer = 1)
Nothing correspond to category 0.
So the correct classification is the one in the PolimiFunct.h
PolimiFunct.h has:
#define PRE_EDGE 2
In the man page there is an error, in fact the category referring to
terrain and edge are switched:
man page says:
The comment in the file edgedetection.c is wrong, probably it is
something left from an old version of the code:
/* 1 = PRE_EDGE */
/* 2 = UNKNOWN */
----- end cite -----
Markus
