[GRASS-dev] Re: [GRASS GIS] #520: r.terraflow/iostream does not respect STREAM_DIR option
Helena Mitasova hmitaso at unity.ncsu.edu
Sun Jul 19 20:47:51 EDT 2009
>> These files are deleted upon successful completion of the module
>> using
>  the iostream lib, nothing left to inspect. They are probably only
> useful
>  for the iostream lib developers for debugging. Same for the
> segment lib,
>  intermediate files are probably only useful for developers working
> on the
>  segment lib. I don't see a reason why files created by the iostream
>  library should be treated differently to files created by the segment
>  library, or vice versa, when it comes to their storage location.
>  +1
>> This discussion is now moving away from r.terraflow towards where to
>  store large temporary files, maybe this ticket can be closed and the
>  discussion be continued somewhere else if needed?
>  No, still /var/tmp/ is the default also in GRASS 7. This should be
>  changed.
yes, please, this needs to be changed, it has been a long standing issue
Helena
>  MarkusN
>> Markus M
> Ticket URL: <http://trac.osgeo.org/grass/ticket/520#comment:21>
> GRASS GIS <http://grass.osgeo.org>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
