[GRASS-dev] GRASS 7: Interactive startup needed - how to avoid?
Mon Jul 20 00:07:10 EDT 2009
Markus Neteler wrote:
> currently no way to start GRASS as I am used to do:
> grass70 ~/grassdata/spearfish60/neteler/
> Cleaning up temporary files ...
> Starting GRASS ...
> GISDBASE, LOCATION_NAME and MAPSET variables not set properly.
> Interactive startup needed.
It doesn't like the trailing slash; it causes the empty string after
the trailing slash to be treated as the mapset.
Try r38468.
