[GRASS-dev] Re: [GRASS GIS] #443: cairo driver: labels are not
rendered
trac at osgeo.org
Fri Jul 24 06:52:14 EDT 2009
#443: cairo driver: labels are not rendered
Reporter: martinl | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Display | Version: 6.4.0 RCs
Resolution: | Keywords: cairo
Platform: All | Cpu: All
Comment (by mmetz):
Replying to [comment:3 hamish]:
> Replying to [comment:2 mmetz]:
> > In the North Carolina dataset,
> d.vect boundary_county attrcol=NAME
> > doesn't work for me nowhere, from 6.4.0RC5 through to 7, any display
driver. In 7, I can't even give an attrcol, that option in the wxGUI
behaves as if it's disabled.
> the above example is missing disp=attr
Hmph. Sorry for the noise, everything is fine. Except grass7, still can't
set option attrcol, also when setting disp=attr first.
> perhaps (attrcol->answer != NULL) should switch on disp=attr if it was
not already given??
Maybe you want the column to be remembered but temporarily switch off
label display?
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/443#comment:4>
