[GRASS-dev] Re: [GRASS GIS] #695: Can't create a location using Select Coordinate System option with WXGUI Location Wizard
Casey Vandenberg casey.vandenberg at sjgeophysics.com
Mon Jul 27 11:29:16 EDT 2009
GRASS GIS wrote:
I shouldn't have listed this as a major defect, because there are
already alternative options for selecting a coordinate system (e.g.
using EPSG code or proj4 definition). Its more of an inconvenience.
If I go through the location wizard and choose the "select EPSG code of
a coordinate system" option, I can navigate through the list, chose a
UTM projection using the NAD83 datum (e.g. Zone 10 N). After hitting the
next button I am given the option to choose my datum transformation
option. The first option says it is the default used in the whole nad83
region (towgs84 = 0,0,0). However this default datum transformation
option is not available when I go through the "Select Coordinate System"
option using location wizard.
I guess I was expecting a "default" datum transformation parameter when
creating a location using the choose coordinate system option, similar
to how it exists with the select EPSG code option.
I have only noticd this with NAD83 projections so far.
Casey
> Location Wizard
>   Reporter:  voncasec  |       Owner:  grass-dev at lists.osgeo.org
>       Type:  defect    |      Status:  new
>   Priority:  major     |   Milestone:  6.4.0
>  Component:  wxGUI     |     Version:  6.4.0 RCs
> Resolution:            |    Keywords:  Location Wizard
>   Platform:  Linux     |         Cpu:  Unspecified
> Comment (by neteler):
>  Which parameters did you expect? We may be able to add them.
>  Markus
