[GRASS-dev] GRASS 6.5 GEOS build fails
Glynn Clements
glynn at gclements.plus.com
Tue Jul 28 11:18:23 EDT 2009
Moritz Lennert wrote:
> > any clue how to compile 6.5 with GEOS support? Vlib fails:
> What did you feed configure ? It should be something like this:
> --with-geos=/usr/bin/geos-config
> This works for me with libgeos-3.0.0.
Ah. With geos-2.2.3, the configure checks pass, but the build fails.
The GEOS configure checks should actually do some checking. Apart from
the version issue, there's no LOC_CHECK_LIBS or similar, so the checks
will pass even if the library is entirely absent.
LOC_CHECK_LIBS checks for a specific symbol, so it should be
straightforward to check for a symbol which is only present in 3.x.
