[GRASS-dev] [GRASS GIS] #706: Location wizard/g.proj: "Do you want
to set the
default region extents and resolution now?" dialog missing on
Windows
trac at osgeo.org
Wed Jul 29 10:21:14 EDT 2009
#706: Location wizard/g.proj: "Do you want to set the default region extents and
resolution now?" dialog missing on Windows
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: location wizard | Platform: MSWindows XP
Cpu: Unspecified |
When creating a new location from georeferenced file (SHAPE with .prj), in
the Location wizard the g.proj part does NOT ask as on Linux "Do you want
to set the default region extents and resolution now?" but returns a
region error message ("region for current mapset is not set", coming from
lib/gis/get_window.c).
Apparently the g.proj call on Windows fails when creating a location from
file.
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/706>
