[GRASS-dev] g.extension.add available to install GRASS Addons SVN
modules (GEM replacement)
Martin Landa
landa.martin at gmail.com
Fri Jul 31 04:06:49 EDT 2009
2009/7/30 Markus Neteler <neteler at osgeo.org>:
>> GRASS_ADDON_PATH is to a bin folder, and can be multiple paths. The prefix
>> for extension installation should be a single path to a standard bin/lib/etc
>> structured folder.
> As emerged earlier, it should be outside of the standard GRASS installation.
> My point was: if GRASS_ADDON_PATH doesn't point to the g.extension
> default, the users will install an extension and then won't find it since it
> is not in the path.
probably g.extension could check if given prefix is in
GRASS_ADDON_PATH and update it if needed?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
