[GRASS-dev] [OSSIM] Ossimplanet integration with Grass and Qgis - status report #9
Massimo Di Stefano massimodisasha at yahoo.it
Fri Jul 31 16:18:35 EDT 2009
Week 10 (August 1, 2009)
What did I do this week:
Bugfixing, gui cosmetics, message-dialogs to manage exception.
Implemented a new function+relative gui to place 3d model (collada .dae)
          inside a kml.
Working on a function to rotate/scale/traslate a vector object, it
will have
         as additional targhet the ability to display projected
coordinates
         (not only geographical)
I get working ossimplanet tcp data messaging using python soket and
          i’implemented a relative gui tool to send/remove grass
raster layer to
          Ossimplandet.
What do I plan on doing next week:
Continue bug fixing, gui cosmetics, cleaning the code.
Investigate if possible to work on a routing function .
finish the module to rotate/scale/traslate a vector object.
Am I blocked on anything:
Nothing block me :-)
Un allegato HTML ? stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090731/54bb82c4/attachment.html
