[GRASS-dev] grass7 on WinGrass Multi.make deps
Mon Jun 1 00:33:23 EDT 2009
Hamish wrote:
> while reviewing & streamlining the WinGrass build instructions I notice
> a work-around is given for the grass 7 Make/Multi.make file which looks
> like it might be a bug. It is step 4 for building GRASS 7:
> https://trac.osgeo.org/grass/wiki/CompileOnWindows#Grass-7.0.svntrunk
Odd. I didn't need to make that change to build GRASS 7 on Windows.
OTOH, I don't see any problem with the alternative.
