[GRASS-dev] GRASS 7: r.in.wms compile failure - ImportError: cannot import name log
Tue Jun 2 14:47:32 EDT 2009
Markus Neteler wrote:
> > Check that $PYTHONPATH doesn't contain any inappropriate directories,
> > and that dist.x86_64-unknown-linux-gnu/etc/python doesn't contain
> > anything except the grass subdirectory.
> Interestingly it works today. Perhaps I had set $PYTHONPATH indeed
> to the swig/python/ directory as suggested in the examples:
> grep PYTHONPATH examples/*
> examples/m.distance.py:    #   export PYTHONPATH=/usr/src/grass70/swig/python
> examples/rasteraccess.py:export PYTHONPATH=/usr/src/grass70/swig/python
> examples/vectoraccess.py:#   export PYTHONPATH=/usr/src/grass70/swig/python
Right; that will cause the problem which you reported.
The only GRASS-related directory which should be added to PYTHONPATH
is $GISBASE/etc/python.
